03 XKR Timing Chain Tensioner surprise
Old Sep 10, 2014 | 10:54 PM
jammin012's Avatar
Default 03 XKR Timing Chain Tensioner surprise
So, there I was worrying about my tensioners and figured why not now to replace them. With this much time on the clock and just under 50k miles I didn't know what to expect. Here's a short post to let you know what I found and ask a couple questions.
Here she is about to get torn apart.
I thought there were 2 bolts holding the intake on.
Question#1 what does this connector go to?
Coil pack cover removed.
Didn't want to mix them up so grabbed some paint and made it easy for me.
Question #2 Did I miss something? I don't remember anyone saying the cam cover had to come off in order to get the 3rd coil pack out.
Cam cover removed and it looks a lot cleaner than I thought.
Oh snap, I already have the updated secondary tensioners, WOOHOO.
I do believe I also have the updated primary and guides as well.
Thanks for all the info, you guys helped a lot.
Old Sep 10, 2014 | 11:43 PM
Marsden's Avatar
Don't all 2003 model V8s have updated design (metal) tensioners straight from the factory?
Old Sep 11, 2014 | 12:21 AM
enderle's Avatar
Default Yep
Supposed to, one of the advantages of getting the newer models.
Old Sep 11, 2014 | 07:32 AM
brgjag's Avatar
pics are not loading.
Old Sep 11, 2014 | 07:35 AM
Post 2003 4.2s don't have the plastic tensioner problem, you haven't been reading the forum enough!
Old Sep 14, 2014 | 09:23 PM
jammin012's Avatar
These should be in order, enjoy
Attached Thumbnails 03 XKR Timing Chain Tensioner surprise-gopr0418a.jpg   03 XKR Timing Chain Tensioner surprise-gopr0419a.jpg   03 XKR Timing Chain Tensioner surprise-gopr0420a.jpg   03 XKR Timing Chain Tensioner surprise-gopr0438a.jpg   03 XKR Timing Chain Tensioner surprise-gopr0441a.jpg
03 XKR Timing Chain Tensioner surprise-gopr0443a.jpg   03 XKR Timing Chain Tensioner surprise-gopr0444a.jpg   03 XKR Timing Chain Tensioner surprise-gopr0454a.jpg   03 XKR Timing Chain Tensioner surprise-gopr0455a.jpg   03 XKR Timing Chain Tensioner surprise-gopr0457a.jpg
toronadomike
Jan 22, 2026 10:13 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
Beardy
Sep 18, 2015 10:00 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
