04 xkr air conditioning pressure
Old Jul 26, 2012 | 01:45 PM
protech's Avatar
Default 04 xkr air conditioning pressure
Gentlemen:
Ambient temp 95 degrees, low side pressure is 55psi but when compressor kicks in goes up to almost 100 psi. Then I assume a high pressure switch kicks in and pressure drops. Yet driving the car there is cooling in the cabin.
Any ideas?
Old Jul 26, 2012 | 02:47 PM
test point's Avatar
Here is the Jaguar ambient temperature chart if that helps. The low side pressure you describe seems strange.
File Type: pdf
Old Jul 26, 2012 | 03:28 PM
You may find this thread interesting reading https://www.jaguarforums.com/forum/s...reasure-54416/
Do you know what the high side is doing?
Old Jul 26, 2012 | 07:19 PM
protech's Avatar
Default Low side pressure
Haven't check high side yet, what I can't figure out is why the low side goes up and down.
Old Jul 26, 2012 | 08:19 PM
Stumpy's Avatar
It is normal when the compressor is not running for the low and high side pressures to equalize. When active the compressor draws gas from the low side and compresses it to a liquid on the high side, this process releases the heat (removed from the cabin air) via the condensor.
During this process it is normal for the high side pressure to increase considerably, enough to make the gas return to a liquid and at the same time release it's heat. At the same time this causes suction on the low side causing it to reduce in pressure. (Both pressures dependant on ambient air temperature) If this pressure falls too low, and everything else in the system is operating correctly, it would generally mean that there is insufficient liquid/gas coming through the evaporator - a lack of refrigerant.
In your case the low side pressure is going higher, and as the cabin air is being cooled this could suggest (one option), there might be too much flow coming through the expansion valve (faulty) to the evaporator and on to the low side reading.
You really need both the low and high readings to be more specific.
Old Jul 28, 2012 | 03:19 PM
H20boy's Avatar
good explanation stumpy!
Old Jul 28, 2012 | 04:50 PM
Stumpy's Avatar
Lightbulb
protech
Another thing that you should check is the climate control diagnostic system, to see if any codes are listed?
Instructions and code information here:
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Skeeter
Sep 17, 2015 08:15 PM
tberg
Sep 7, 2015 07:32 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
