1997 Jaguar xk8 both tail light assemblies went out
Old Mar 4, 2008 | 06:02 PM
GordoCatCar's Avatar
Default RE: 1997 Jaguar xk8 both tail light assemblies went out
First thing I would check is your ground connection. gordo
Old Mar 4, 2008 | 07:05 PM
jag_genius's Avatar
grounds always melt.. sometimes it melts the whole plastic connector ..
Old Mar 5, 2008 | 09:56 AM
Can you pull off the panels and look-see the housing and harness? Follow the wiring harness to where you see one or two wire end connectors attached by screws to the body structure. You should be at the end of the harness back there so the number(s) of wires will be limited. gordo
Old Mar 7, 2008 | 08:18 PM
FactoryJaguarTech's Avatar
I would unplug one of the lamp assemblies one at a time first. See if the other comes back to llife. If not, plug back in and try other side.
BrentGardner
29
Dec 16, 2024 12:13 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
jdzubas
Oct 4, 2015 09:14 AM
201motels
Aug 30, 2015 08:03 PM
rwoodlin
Aug 29, 2015 04:32 PM
