1997 XK8 Code P0153
Old Jul 19, 2012 | 11:45 AM
Rip Reed's Avatar
Default 1997 XK8 Code P0153
what does code po153 on a 1997 jaguar xk8 thanks
Last edited by GGG; Jul 19, 2012 at 05:57 PM. Reason: edit typo in thread title so it appears in searches
Old Jul 19, 2012 | 02:46 PM
MRomanik's Avatar
Veteran: Air Force
Here you are:
P0153 :HO2S sense circuit slow response – B bank, upstream
Monitoring conditions:
Engine at normal operating temperature; a drivet 50 – 62 mph
engine speed 1500 – 2500 rpm>10 seconds
Default Action:
When CK ENG MIL is activated (DTC flagged; second trip),
ECM:
– Inhibits B bank closed loop fuel metering
– Inhibits B bank adaptive fuel metering
Possible causes:
Engine misfire
HO2S disconnected
HO2S mechanical damage
HO2S to ECM wiring intermittent open circuit
HO2S sensing circuit short circuit to high voltage
HO2S short circuit to ground
HO2S ground (BRD – braided shield) open circuit
HO2S heater circuit fault
Exhaust leak
Low exhaust temperature
Injector flow partially blocked
Catalyst efficiency decrease
HO2S failure
toronadomike
Jan 22, 2026 10:13 PM
DevonDavid
Jan 8, 2026 03:12 PM
42Ajd
Dec 30, 2015 09:45 AM
speacock
Sep 14, 2015 07:57 PM
Bowman
Sep 3, 2015 03:17 PM
