1997 xk8 conv. top question
Old Feb 26, 2014 | 09:50 AM
mike mitchell's Avatar
Talking 1997 xk8 conv. top question
my xk8 has 68000 miles, and is stored winters. (live in Mich.) Lately, when raising and lowering the top, the main clamp doesn't lower. If I play with it, it will finally lower. Any help? Oh yeah.... The other day, I had to take her out in zero weather. After arriving at my destination, I was idling for about ten minutes, and my oil gauge went to 0, and engine light came on. Turned car off and waited a couple minutes. Restarted it, and she was fine. Six hours later, drove home with no problem. Hoping for moisture in sending unit, or just a one time anomaly. I had a rebuild two years ago, and has been running great. Mobile One oil, if that means anything. Thanx again
Old Feb 26, 2014 | 09:54 AM
MRomanik's Avatar
Veteran: Air Force
1st thing to check,make sure your battery is fully charged.These cars are very sensitive to battery voltage.
Old Feb 26, 2014 | 10:09 AM
Wow,, that was fast. But, yeah, brand new battery. Think it needs some kind of Lube?
Old Feb 26, 2014 | 10:25 AM
WhiteXKR's Avatar
Check that the pump fluid level is between the two embossed lines so the tank (RH side in trunk). Also if you have the yellow or brown fluid it needs to be replaced with the green colored Pentosin CHF-11S fluid. The original fluid gels when it get old.
As for the oil pressure, remove the oil pan and check for a clogged sump. It can clog with plastic bits from broken tensioners and guides. Also replace the low pressure switch (next to the oil filter)...it is less than 20 bucks.
Old Feb 26, 2014 | 10:28 AM
Mike,
I've moved your question from General Tech Help to XK8/XKR forum as it's a model specific question.
Members here with the same model will interested in the topic and more will see it here.
99xk8guy
Sep 29, 2025 10:51 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
TXJagR
Jun 20, 2016 01:02 PM
Bret_T
Sep 4, 2015 05:01 PM
brgjag
US Midwest
Sep 4, 2015 11:24 AM
