1997 XK8 oil pressure sensor
Old Oct 13, 2020 | 09:36 PM
Mel Horman's Avatar
Default 1997 XK8 oil pressure sensor
My oil pressure sensor is 10x1.25. I'm trying to find a T to add a gauge. I can't find any in the 10mm. Is 1/8" bspt the same size as 10x1.25. Thanks. Mel
Old Oct 14, 2020 | 05:42 PM
avern1's Avatar
Short answer NO. British Standard Pipe Thread is the same as SAE pipe thread except for the angle of the threads. BSPT is cut at 55 degrees and SAE Pipe is cut at 60 degrees, but both are tapered.
You will have to get creative for a work around. follow the link below to McMasterCarr they have a 10 mm male to 1/8 pipe adapter, form there you can fit 1/8 pipe but to get the sensor back you have to go 1/8MPT to 10mm female.
Old Oct 15, 2020 | 04:21 AM
astromorg's Avatar
This is the ready made solution
Jaguar V8 Oil Pressure Adapter - TheJagWrangler
Mel Horman
Oct 13, 2020 10:09 AM
giandanielxk8
Sep 6, 2015 07:21 PM
FrozenApple
Jun 25, 2015 08:31 AM
Rhett
Feb 25, 2014 10:24 PM
JagYour
Jul 5, 2012 07:55 PM
