1997 XK8 rear windows
Old Apr 29, 2022 | 12:34 PM
jonnb33's Avatar
Default 1997 XK8 rear windows
1997 xk8 rear windows to come up? looking for suggestions, I have to manually lower and raise the top due to a hydraulic hose leak
Old Apr 29, 2022 | 07:05 PM
if the rams are not fully engaged, the windows will not raise with the switch - you need to gently pull up on the rams to ensure they are locked and then try to raise the windows
Old Apr 29, 2022 | 07:07 PM
jonnb33's Avatar
thank you I will try that
Old Apr 30, 2022 | 06:57 AM
JagRepair.com - Jaguar Repair Information Resource
Old Apr 30, 2022 | 09:07 PM
Addicted2boost's Avatar
Have you tried using the key in the drivers door to global close the windows? I know you can global open all 4 windows with the key.
Old May 2, 2022 | 07:30 AM
jonnb33's Avatar
yes they went down a little but will not come up
Old May 2, 2022 | 10:36 AM
NorXKR's Avatar
Per Greibe Soerensen
Apr 19, 2022 09:37 AM
mustangmoon
Nov 23, 2020 04:44 PM
JagXK82001
Apr 26, 2017 08:55 PM
jdperformance
Oct 21, 2014 10:01 PM
motomental
Aug 16, 2013 06:55 PM
