1998 Door mirror master switch
My mirrors won’t adjust with the joystick on the door master switch. The mirrors move when using the memory.
I disassembled the switch and cleaned the corroded contacts. No change. I replaced the switch with one from a breakers yard. First I inspected it for corrosion. Found none. Still, neither mirror will move .
I probably will need a wiring schematic and trace power. Anyone have any other better plan?
98 xk8 convertible
98 xk8 convertible
Ltd, did you get continuity through the switch positions after cleaning? IOW does moving the joystick/selecting the side close the connection to different outputs on the switch traces? That way you'll know if the problem is in the switch or elsewhere in the circuit.
I spent way too much time focusing on my tilt telescope switch trying to figure out why I couldn't get it to move the steering wheel. Years later I replaced my turn signal assembly stalk and harness for a different problem. To my surprise it fixed the tilt / telescope issue!
John
John
Ltd
