1998 jaguar xk8 lights stay on
Old Aug 1, 2016 | 04:32 PM
al101's Avatar
Default 1998 jaguar xk8 lights stay on
Second attempt at resolving this problem
would appreciate some help
My xk8 lights will not turn off the only lights i am able to turn off are the headlights, running lights tail lights all stay on
I checked the head lamp relay but that was not it
Old Aug 2, 2016 | 10:17 AM
247 Views and 0 theories!
My first suspect would be the column switch ........
Old Aug 2, 2016 | 10:31 AM
avern1's Avatar
Since it will shut off the headlights and not the remaining lights, I would think you have a loose or shorted wire in the Stalk multi switch. The norm for a loose wire would be intermittent operation or none. It is possible that one of the wires is creating a ground causing the lights to stay lit.
I would remove the covers on the steering column and start checkiing the connections to the stalk. The stalk is the only point that i think all of the other wires come together.
If the wires don't seem to be causing a problem them I would replace the stalk switch.
Old Aug 2, 2016 | 12:37 PM
Fulton's Avatar
Do the lights turn off when the engine is off and the key out?
If so it is a setting, Jags are homogenized for the North American Market, Canada must have running lights. Yours could be turned on. Visit the dealer to have them turned off.
Old Aug 2, 2016 | 01:56 PM
al101's Avatar
Default multyiswich
the lights stay on only the head lights turn off
I replaced the multiswich in September because it was broken brand new from the dealer I have had bulb failures due to a bad ground in the tail light connections that i fixed that
Old Aug 2, 2016 | 02:41 PM
michaelh's Avatar
So, if I understand your symptoms, when you remove the key, irrespective of where the lighting stalk is set, the sidelights & side marker lights remain on?
In which case, you must have to keep putting the battery on charge?
Is this correct?
Mike
razorboy
May 5, 2016 09:57 PM
Mar 3, 2007 11:37 AM
Jan 22, 2007 12:38 AM
Dec 23, 2006 01:15 AM
andersen06
Sep 18, 2006 12:18 AM
