1998 XK8 radio problems
Old Nov 12, 2012 | 05:44 PM
dinaros's Avatar
Default 1998 XK8 radio problems
Just acquired a 1998 XK8, love it. Everything works great except the stereo. If volume is turned up it make a buzzing / humming noise,no other sound. If I turn it off and back on again it's ok until I turn it back up again. Would this be the radio or the amp. Also the knob is erratic on the radio when changing settings, fade-balance-volume etc, will go from plus to minus when trying to adjust, . Volume works ok from steering wheel. Help....
Old Nov 12, 2012 | 07:33 PM
bluexk8ragtop's Avatar
Good day,
I don't know if the knob is a hall effect unit or an electrical connection type... I'm thinking the latter and is the cause of your issues... I'd just use the steering wheel controls or swap the radio... I don't know of any repeated issue with the radio knob...
Good luck and let us know what you did to fix it...
Cheers!!
Old Nov 12, 2012 | 09:43 PM
dinaros's Avatar
Default radio problem
Thanks, really weird, if I turn the knob clockwise to turn up the volume it goes to 3 then 4 then maybe back to 1 then maybe 6 or 5, has a mind of it's own, same with trying to adjust fade or balance. I buy and repair and sell camcorders and once in awhile I get one that the menu dial is erratic, I spray contact cleaner around the dial and usually cures that problem. Maybe I'll try that befor replacing it. I ordered an amp from ebay, hope that cures the other problem.
Dinaros
Old Dec 26, 2012 | 11:08 PM
dinaros's Avatar
Originally Posted by bluexk8ragtop
Good day,
Cheers!!
Ended up replacing everything, radio, all speakers, installed sub woofers with amp and amp for the head unit. really sounds great.
Attached Thumbnails 1998 XK8 radio problems-004.jpg   1998 XK8 radio problems-005.jpg   1998 XK8 radio problems-006.jpg
Old Sep 6, 2013 | 10:42 AM
rtucker's Avatar
Default 1997 XK8 steering wheel radio control erratic operation
My 97 XK8 Convertible has started a niggling problem. The volume up button on the steering wheel does not respond but if I press the change disk button the volume sometimes works.
The volume on the radio itself works perfectly
I would like to check the unit but am not sure to go about this. Does anyone have the instructions as to how to get to the unit (removal of horn button I guess) or any ideas as to what the problem could be?
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
philwarner
Oct 4, 2024 01:37 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
Rlover
Mar 30, 2016 10:04 PM
