1999 XK8- Battery Draining- BPM or lamps suspect
Old Apr 22, 2015 | 03:45 PM
tommyswift's Avatar
Default 1999 XK8- Battery Draining- BPM or lamps suspect
The battery on my XK8 has been draining intermittently during the past few months, and for the last two weeks it has been draining regularly after 2 or 3 days of sitting.
After fully charging the battery, I used a multimeter and pulled each of the fuses to check for drain, which is fairly consistent at .2 amps. However, the drain ceases when the Body Processor Module (5V logic and lamps), fuse 5 on the Fascia Fusebox, Driver's side, is pulled out.
Does anyone have a suggestion on how to proceed? I am guessing that it may be a bulb or connection, but I am not certain which bulbs are on this circuit. From what I have read on the forum, if a bulb isn't to blame, it's time to take it in for a pro to find a BPM or 5V logic circuit issue.
Any help would be greatly appreciated.
Thanks and have a great time driving this spring!
Old Apr 22, 2015 | 04:01 PM
batroute's Avatar
First check that the cover on the ignition switch closes when you remove the key - if it is stuck open the car will not go into sleep mode and that will discharge the battery in the manner you describe. If that's the problem it's easily fixed with silicone spray.
Old Apr 23, 2015 | 08:26 AM
jimforrest (uk)'s Avatar
Batroute is dead right - my 2000 XK8 did the same thing. Spray the WD40 on the key and not in the ignition lock though! In and out a few times and the problem will stop.
Old Apr 23, 2015 | 12:57 PM
tommyswift's Avatar
Thanks very much for the rapid responses. I will go ahead and try that out when I get home from work.
Old Apr 25, 2015 | 08:53 AM
wolfpck1's Avatar
also read that even tho its parked locking the doors when parked also induces the sleep mode may try that also.
Old Apr 25, 2015 | 09:26 AM
No it doesn't - my XK battery went flat over 2 or 3 days even when deadlocked. Freed the flap off (you can see it's open) and the problem went away.
Forcedair1
Sep 8, 2025 01:57 PM
Dagny
Jun 11, 2024 01:06 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DEklof
Sep 8, 2015 05:28 PM
al_roethlisberger
Sep 7, 2015 10:53 PM
