1999 XK8 convertible & jack stands
Subscribe
Sep 8, 2021 | 11:36 PM
Where's the best place to put jack stands under the above car (need to replace lower control arm bushings).
Reply 0
Sep 9, 2021 | 07:59 AM
Markle, at the rear of the front wheel well is a bracket just inside the lip with a couple of nuts. Very stable place for the front ones.
The rear wheel well has a like place just in front of the opening. Always push a car from a couple of different directions for safety, if you are getting all four wheels off the ground. Not a bad idea to leave the jack under your jacking point in the front or rear with a bit of pressure on it, if you have two jacks, as you will need one to help with the front suspension job.
Reply 3
Sep 10, 2021 | 10:18 AM
Thank you Sir
Reply 1
Subscribe
Currently Active Users (1)
