1999 XK8 convertible & jack stands
Markle, at the rear of the front wheel well is a bracket just inside the lip with a couple of nuts. Very stable place for the front ones.
The rear wheel well has a like place just in front of the opening. Always push a car from a couple of different directions for safety, if you are getting all four wheels off the ground. Not a bad idea to leave the jack under your jacking point in the front or rear with a bit of pressure on it, if you have two jacks, as you will need one to help with the front suspension job.
