1999 XK8 coupe.... gearbox problem?
Old Mar 23, 2009 | 03:59 PM
Mr T's Avatar
Default 1999 XK8 coupe.... gearbox problem?
hi all,
looking for some tips or suggestions with a problem.
when you put the car into 'drive', it gives a 'thud' when engaging into drive. this is more prominent when engaging reverse. the 'thud' into gear seems more harsh when the car is cold. when warmed up, it doesnt seem to do this. also, i've recently noticed that when i am on a slope and i need to engage reverse, it seems to hesitate before engaging reverse, and then when it does, its with a hard 'thud'. i've read somewhere before that every so often, you need to put it into 'sport' mode and drive your normal driving so that the gearbox can 'reset' itself. this has worked in the past, but not now.
has anyone experienced this kind of problem?
any help or advise would be welcome
by the way, i have no error codes yet.
thanks
T
Old Mar 23, 2009 | 06:51 PM
JackJohn's Avatar
It could of course be a number of problems but I'd first check the "U" joints to see if you have a sloppy one.
Old Mar 24, 2009 | 01:56 PM
Mr T's Avatar
thanks for your reply jackjohn.
i'm a bit of a DIYer but no expert, could you elaborate on whats a 'U' joint?
thanks T
Old Mar 24, 2009 | 02:05 PM
Brutal's Avatar
what Jacks reffering to is the JURID coupling, the front and back off the driveshaft that is bolted to the trans and the differential. Both of which Ive seen loosen and need to be tightened. But also clunks like that are also from broken/worn bushings, be it shock or suspension pieces in the rear
Old Mar 24, 2009 | 02:28 PM
Mr T's Avatar
thanks for the explanation brutal. i'll definately have a look at the joints. i somehow dont think its coming from the suspension, it only jerks into gear when you put it into 'drive' from a standstill, and as i previously said, when you engaging reverse, it seems to hesitate for a split second then jerks into gear (kind of freightning if your trying to do a quick turnaround!)
T
Old Mar 24, 2009 | 06:33 PM
JackJohn's Avatar
Thanks Brutal, I guess the term "U" joint rather dates me.
Old Mar 24, 2009 | 10:21 PM
Brutal's Avatar
lol, and you think since I knew it doesnt....actually theyre still widely used, but the part youre referring to Jack is a big rubber donut and called a Jurrid coupling.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
cissdm
May 3, 2016 06:02 AM
jdzubas
Oct 4, 2015 09:14 AM
pnwrs2000
Sep 3, 2015 11:55 AM
