1999 XK8 lamp control module...
Old Oct 9, 2013 | 08:38 PM
thefixer's Avatar
Question
I've got a 2003 XKR, as has a friend. He's a got a problem where he's getting a message re failed read lights, though they're all working well.
He's been advised to purchase a new SLCM, but I'm going to take a look at it before he takes that step. Looking at this thread, it looked as if the LCM would be the problem, but looking at the JTIS for 2003, I can't see a LCM on the diagrams for rear lighting. Is there one? It looks as if all the lighting circuits go into the SLCM directly.
Thanks in advance
PS And if there's not an LCM, what's the black box fitted in the rear of the trunk mounted fuse box that has two connectors? Unfortunately it has no labels visible, as it's covered in sticky backed foam
Old Oct 9, 2013 | 08:51 PM
WhiteXKR's Avatar
Thanks in advance
Later models have integrated the LCM into the security module.
Check that all the bulbs are the correct types as specified in the owners manual. The wrong wattage can trigger a bulb fault.
If they are all OK, then clean the contacts on the bulbs and tail light connector with commercial contact cleaner.. Also inspect the tail light connectors, especially the black (ground wire) pin. If there is any sign of wear, burning or melting on this contact, ground the taillight direct to the chassis.
Old Oct 9, 2013 | 09:56 PM
thefixer's Avatar
Thanks. I'll be sure to check out all the bulbs, and the GNDs.
I'm assuming that swapping the SLCM's between our cars wouldn't that easy (as they're somehow key'd to the remotes?). Having two near identical cars I was considering doing some parts swapping to get to the root of this.
-Steve
mrplow58
Jan 21, 2024 05:53 AM
abonano
25
Sep 25, 2015 10:43 AM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
jimmiejag
Sep 9, 2015 02:56 PM
