1999 XKR transmission fluid
Can anyone tell me the correct fluid (or correct equivalents) available in the UK for my 1999 XKR? I've looked around, but there seems to be a bit of confusion; as I understand it, the XK8 and XKR have different boxes and use different fluid.
Thanks!
Thanks!
Mobil ATF 134. Best for MB transmission.
Hi Frozennorth,
Have a look here: Mercedes-Benz 722.6 Transmission FAQ - Mercedes-Benz Forum
The 4.0 XK8 used the ZF 5 speed unit, but the SC XKR 4.0 had the Mercedes Benz 722.6 5 speed unit fitted to deal with the extra torque more reliably.
I wanted to do an oil change on my box and did some research, as there are a lot of different opinions floating around on the net. My personal opinion is to use an oil approved by the manufacturer and in the link above you will find a list of Mercedes approved oils and a lot of general information relating to these very strong gearboxes.
Hope this helps.
Andy
Hope this helps.
Andy
aholbro1
Dec 29, 2024 06:46 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
