1999 XKR transmission fluid
Old Jan 12, 2014 | 04:03 AM
frozennorth's Avatar
Default 1999 XKR transmission fluid
Can anyone tell me the correct fluid (or correct equivalents) available in the UK for my 1999 XKR? I've looked around, but there seems to be a bit of confusion; as I understand it, the XK8 and XKR have different boxes and use different fluid.
Thanks!
Old Jan 12, 2014 | 04:13 AM
smithtrevor's Avatar
Any good to you ?
ZF Transmission Oil Reference Guide PC 102307.pdf
Old Jan 12, 2014 | 04:31 AM
XJR-99's Avatar
Thanks!
Mobil ATF 134. Best for MB transmission.
Old Jan 12, 2014 | 06:12 AM
Andy Cox's Avatar
Hi Frozennorth,
Have a look here: Mercedes-Benz 722.6 Transmission FAQ - Mercedes-Benz Forum
The 4.0 XK8 used the ZF 5 speed unit, but the SC XKR 4.0 had the Mercedes Benz 722.6 5 speed unit fitted to deal with the extra torque more reliably.
I wanted to do an oil change on my box and did some research, as there are a lot of different opinions floating around on the net. My personal opinion is to use an oil approved by the manufacturer and in the link above you will find a list of Mercedes approved oils and a lot of general information relating to these very strong gearboxes.
Hope this helps.
Andy
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
kstevusa
Sep 7, 2015 01:12 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
