2000 xkr radiator
Old Dec 2, 2014 | 01:33 PM
stetson1's Avatar
Default 2000 xkr radiator
Hey, i'm in the process of repairing my 1999 xk8 after a front end collision. I bought a 2000 xkr donor car and am having the front put on my car. Question, WILL THE RADIATOR that came with the XKR be made to work in my XK8, with some fittings for the lines? The dimensions are the same, I think, but the fittings are different, I think, thanks.
The radiator does have a sticker on it that says SUPERCHARGED ONLY, but, hoping it can be made to fit.
Old Dec 2, 2014 | 02:16 PM
randyb's Avatar
I have an XKR radiator in my XK8, you just need to block off the upper return hose, that goes to the resevoir, it is right above the upper tranny line and you need to adapters for the tranny lines.
My car is a 2001.
Old Dec 2, 2014 | 02:42 PM
brgjag's Avatar
Sorta related.
On my 03 xk8 (non R) I have a nipple/plastic line sticking out on the top drivers side of the radiator. No hose going to it. Should that be capped, right now there is nothing on it.
Old Dec 2, 2014 | 03:07 PM
randyb's Avatar
Originally Posted by brgjag
Sorta related.
Yours is already blocked (XKR's are open).
Old Dec 2, 2014 | 11:39 PM
Jag#4's Avatar
randyb is correct. I had both radiators sitting in my garage at one point and the only difference is the transmission line fittings and the upper return hose fitting (plugged vs. non-plugged).
Old Dec 3, 2014 | 08:53 PM
Sentinelist's Avatar
Anyone else's radiator cover on the top fiberglass and deteriorating? I have to be careful not to touch it or my hand will turn to fire for a few days.
peterg19
Feb 10, 2023 09:02 PM
Super Cat
Sep 9, 2015 03:24 PM
stype40
Sep 9, 2015 08:14 AM
Xkr x100
Sep 6, 2015 08:50 AM
obwoodie
Sep 3, 2015 07:45 PM
