2001 ragtop stops working
Old Sep 23, 2022 | 10:34 AM
Potvinguy's Avatar
Default 2001 ragtop stops working
My ragtop came up but wouldn't latch. And now it won't move at all. I can toggle the switch and hear relays clicking in trunk. Checked the fuses and they are good. But no hydraulic action at all. No leaks. What am I missing?
Old Sep 23, 2022 | 03:32 PM
motorcarman's Avatar
Sounds like the switches are 'out-of-sync'?
Loosen the hydraulic pump valve on the side of the unit and pull the top down tight to MANUAL latch the top.
Hopefully the Allen tool is still attached to the 'holders' near the open/close valve.
8mm or 10mm (can't remember which size) hex tool will work to rotate the latch open/close to trap the top closed.
All this should be in the owner's manual.
Once the switches are set to CLOSED, the top might begin to operate normally?
Old Sep 24, 2022 | 12:30 PM
Potvinguy's Avatar
Motorcarman, you live up to your handle! I did as you described (also in user manual, 8-3). The Allen wrench was missing, but I found the right one (8mm) in my shop and latched the top. Then turned the pump valve fully clockwise...and it works! Up and down. These cars are crazy complicated, but sure are fun.
steveng
Aug 24, 2019 04:01 PM
jag92
Jul 25, 2017 03:58 AM
S Daddy
Oct 9, 2016 10:16 AM
platinumcat1002
Sep 13, 2011 04:03 PM
