2001 xk8 headgasket replacement
Old Apr 5, 2022 | 01:50 PM
Mitro's Avatar
Default 2001 xk8 headgasket replacement
Getting prepared to change our head gaskets and expansion tank on 2001 xk8 coupe
I am doing this in Athens Greece in a few days
What tools are needed to make sure it is done correctly and any special instructions from all
your experience
Old Apr 5, 2022 | 06:06 PM
michaelh's Avatar
That's going to keep you out of mischief for a while
I've attached the JTIS cylinder head R&R, but I recommend you download the 2nd edition Workshop Manual from the stickies here:
https://www.jaguarforums.com/forum/x...00/#post201829
Do a page search on 'workshop'
You're going to need a timing kit, and something to break that wretched crank bolt free (replace with new). I don't see any cooling parts in your kit, so consider replacing any/all rubber and plastic components as part of the job - particularly the valley hoses & the thermostat tower while you have the top of the motor apart.
Does the car still have plastic tensioners?
File Type: pdf
Old Apr 6, 2022 | 06:21 AM
Pistnbroke's Avatar
If its the right hand head change the starter motor while you can get at it .
Torque wrench and a brain.
DaveCB
Oct 1, 2021 02:48 PM
JagHag36
Jun 14, 2018 11:26 PM
Kevin D
Apr 11, 2009 11:06 AM
Apr 23, 2007 12:16 AM
