2001 xk8 headlight wiring
Old Aug 2, 2015 | 09:20 PM
susie's Avatar
Default 2001 xk8 headlight wiring
I bought a xk8 convertible that someone has done some creative wiring with. So the headlights aren't working. My question is if anyone knows the proper order to plug the wires in. Have wiring diagrams, but they really don't explain which plug goes to which light.
Old Aug 2, 2015 | 10:28 PM
WhiteXKR's Avatar
If you look at the wiring diagram http://jagrepair.com/images/AutoRepa.../jagxk2001.pdf, Figure 9.1, the connectors are labelled LF21-# and LF31#. # is the pin number, which should be embossed on the connector shell (you might need a bright light and magnifier to see it).
The color of the wire is on the line connecting to the connector pin label in the diagram, such as 'U' for blue or 'UY' for blue-yellow. The full list of color codes is on page 13 of the above PDF.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
May 28, 2024 09:36 PM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
laserguy
Sep 3, 2015 02:02 PM
