2001 xk8 trunk wiring
Old Oct 21, 2014 | 05:08 PM
cobrawet2's Avatar
Default 2001 xk8 trunk wiring
Hello
I have a wire in the trunk that has been cut off and I dont know where it goes.
It is in the wire harness coming forward from the trunk fuse box by the passenger side bumper aft of the battery and runs along the outboard side of the battery before it makes a turn to towards the center of the car......
Right in the area the harness bends to the left, there is a green/white wire enclosed in a black sheath. It should be obvious as it looks like the only wire exitiing from the harness at that point.
For the life of me I can not see where the other end is even after rotating the wire around in a radius to look for connection.
Anybody that has a 2001 xk8 (convert??) and can spend a minute looking in their trunk would be appreciated.
Other years may be the same......dont know.....but wire is green/white.
Thanks in advance!!!!
(I have the wiring diagram.....all 146 pages, but can not figure it out....lol)
Old Oct 21, 2014 | 05:44 PM
DevonDavid's Avatar
There's a white/green wire which is the +12v supply to a telephone module in the trunk. Maybe your car had one of these originally - now removed as they are pretty much obsolete these days.
Old Oct 21, 2014 | 05:50 PM
cobrawet2's Avatar
That almost makes sense!!!!!!!!
I am going to try and find a 2001 for sale and look in trunk.......if it is the telephone will ignore!
Love this forum
Old Oct 21, 2014 | 06:35 PM
stevepaa's Avatar
MY 2000 had the telephone module against the rear wall of car, MY 2001 do not have it
Can you take a pic. I currently have a 2001, had a 2000
where are you located?
Old Oct 22, 2014 | 01:52 PM
WhiteXKR's Avatar
Look for the 'transit-isolation device' on the left of figure 1.1 of your wiring diagram. You'll see the white/green wire. The device is for new car transport only and is removed by the dealer.
Old Oct 22, 2014 | 05:19 PM
cobrawet2's Avatar
OK....found it!
I will trace it back and see where it is on the connector plug.......it seems to be in the correct harness.
THANKS!!!!!
Makes sense there is no "other end" visible.....
Old Oct 22, 2014 | 05:34 PM
cobrawet2's Avatar
Reading another thread, it seems it is attached to the battery which is just the right length for the wire and would explain why it has a black rubber tube over it.
I will relax......thanks again!
toronadomike
Jan 22, 2026 10:13 PM
mbergen
Oct 23, 2019 10:26 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
skadmiri1
Sep 9, 2015 11:27 AM
Kmw
Sep 8, 2015 04:52 PM
