2001 XKR- rear suspension options?
Old Mar 21, 2025 | 08:07 AM
2500DollarXKR's Avatar
Default 2001 XKR- rear suspension options?
Was there in 2001 a different set of options on the XKR with regard to rear suspension? Were they all electronically adaptive or were some manual? Also, mine are pretty well shot- clonking and rattling from the rear with a definite lack of stability. Is it common for the shocks to fail themselves (100K on the clock) or is it the bushings?
Old Mar 21, 2025 | 10:11 AM
dibbit's Avatar
I'm pretty sure all the XKRs had CATS suspension. Your clonking is almost certainly the shock bushes have failed - you can see them easily enough if you get under the car. The top mounts are no doubt on the way out also.
Old Mar 21, 2025 | 10:31 AM
Thanks. I have to investigate whether or not that's a job I can tackle myself or if I need special compression tools, etc...
Old Mar 21, 2025 | 10:56 AM
LMG's Avatar
LMG
You can replace the bushes with just a simple press kit. Simon at Projects in the Barn made this excellent video showing it in detail.
Old Mar 21, 2025 | 11:46 AM
dibbit's Avatar
The only special tool you need is a bearing press to get the bush out/in.
https://www.jaguarforums.com/forum/x...5/#post1928458
Have a read of Rothwell's description of how he did his upper mounts using a jack to make enough space to get the shock tower out.
Old Mar 21, 2025 | 11:49 AM
Thanks for that. I just went out and compared the junk XK8 to my XKR. The XK8 is dampened nicely. the XKR is literally just springs and bounces like a trampoline. oof.
EDIT: I just realized I have full access to a Dake arbor press. Might work for the bushings...
Old Mar 22, 2025 | 09:30 AM
dfbender's Avatar
Jaguar XK8 project #21 rear suspension lower shock bush replacement
I’m following Simon also. My lord what an ordeal. Lots of great information on much of what we share here too.
JaguarXKR
Oct 17, 2024 12:55 PM
Kwilkerson2008
Aug 19, 2023 07:17 AM
XxSlowpokexX
Feb 17, 2016 06:03 PM
