2002 Jaguar XK8
Old Feb 9, 2020 | 04:06 PM
Stephen Hilsdon's Avatar
Default 2002 Jaguar XK8
I have no power anywhere! Battery test to have 12 volts and is only 2 years old tops. What do i do or even look for?
Old Feb 9, 2020 | 05:46 PM
Welcome to the forums Stephen,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
When you get as minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Feb 9, 2020 | 06:57 PM
RJ237's Avatar
The battery should have a minimum of 12.4V. If you have 12V with the key off it's probably down to 10 with the key on. But wait, are you measuring with a meter or looking at the dash gauge, which is useless.
Old Feb 9, 2020 | 07:08 PM
DavidYau's Avatar
Default Battery cables
Stephen,
First thing DIY to check is the state of the battery. Is it in the car? You don’t mention if you’re handy with a wrench in the garage. Do you have a multi meter to check the voltage independently?
Is there zero power to anything? Is the car 100percent dead? My guess would be bad battery cables. Take trunk floor panel out and see. Are the battery terminals clean and tight? Worth checking both ends of both cables and the body terminals. The positive cable goes to the High Power Protection junction box. This bolted connection can work loose.
Good luck.
Old Feb 9, 2020 | 07:33 PM
mhminnich's Avatar
Even a low battery would power something. Do you really mean nothing at all is powered?
William Brooks
Jan 19, 2019 03:21 PM
jaguarcat
Jul 8, 2014 05:21 AM
bensico
May 10, 2012 02:04 AM
kgrosse
Aug 2, 2011 08:47 PM
BugDoc
Jan 26, 2009 11:06 PM
