2002 rear strut question
Old Aug 29, 2022 | 12:34 AM
Skyhawk50's Avatar
Default 2002 rear strut question
Just took my 2002 XKR coupe into a shop for State Safety Inspection. I was advised that my rear struts won’t pass because the are “shot”. His exact words. I asked if they were leaking. He replied “they won’t compress” causing rear tire cupping. In other words, pushing down on the rear of the car was difficult.
Does this sound legit? I always thought that when struts went bad, they compressed easily and caused the car to “bounce” when driving and were easy to push down on the rear.
Any thoughts?
Maybe I should find a new shop!
Old Aug 29, 2022 | 12:40 AM
baxtor's Avatar
Any thoughts?
Being the suspicious cat l am l would be checking for myself. Try a jack under lower spring or damper mounting point and lift. Lifting just one side in that way should compress spring and damper before moving the body.
Not sure what they were using to compress things but my body weight has very little success in compressing my own suspension.
Old Aug 29, 2022 | 12:45 AM
Skyhawk50's Avatar
I’ll give it a try with the jack.
On a side note, the car has adaptive dampening. The stationary mode for the shocks is hard. They only have 2 modes, soft and hard. Nothing in between. The accelerometer sensors should dictate shock mode when accelerating or slowing down/stopping. I wonder if this would cause them to appear to be failed. In the past if a shock went bad, it was very easy to compress.
thanks
Old Aug 29, 2022 | 06:17 AM
Jon89's Avatar
Before doing anything to the shocks, I would take the car to a different inspection station. It may pass with flying colors....
hawaiianjag
Aug 30, 2022 10:16 AM
paulgorringe
Feb 12, 2022 01:43 PM
Tomasz Lizer
Dec 8, 2021 09:16 AM
sadepol01
Feb 11, 2016 08:22 PM
