2002 xk8 atf
Old Jan 11, 2025 | 06:49 PM
Drdaffy's Avatar
Default 2002 xk8 atf
I am going to put a new pressure regulator valve in my transmission, ZF5HP24.
My Jaguar service CD calls for Shell M1375.4
ATF for the refill. There are several options since it appears the Shell is not available. What is the best alternative?
Also, any tips on replacing the pressure valve will be greatly appreciated.
Thank you forum members.
Old Jan 12, 2025 | 04:14 AM
RichardS's Avatar
The obvious choice would by ZF Lifeguard 5 which was not available when the car was released but is fully compatible with all 5HP gearboxes.
I actually use Mobil LT71141 which is cheaper in the UK than Lifeguard and is identical and was the original recommended fluid over here. I believe that it is known as Esso LT71141 in the USA, assuming that it is still available over there.
Richard
Old Jan 12, 2025 | 07:50 AM
motorcarman's Avatar
Febi Bilstein Automatic Transmission Fluid - 29738
Old Jan 12, 2025 | 07:54 AM
michaelh's Avatar
? AFAIK, that is a fluid for the 6-speed 6HP26 fitted to the 4.2L. It is not the same as used in the 5HP24.
There are a few alternatives to Lifeguard 5:- LT71141, VW, Peugeot, etc. Grab yourself some popcorn and do a forum search on 'best trans fluid...'
Here's a post which contains a list of them:
https://www.jaguarforums.com/forum/x...2/#post2790110
For the TransGo valve, see this superb how-to from BobRoy and DonB:
https://www.jaguarforums.com/forum/x...2/#post1648275
Old Jan 13, 2025 | 05:10 AM
markmywords's Avatar
Lifeguard! yes expensve, but cheaper than g'box!
Drdaffy
Jan 2, 2025 05:06 AM
ericnunez
Oct 29, 2023 11:02 PM
SC_Gamecock
General Tech Help
Jul 8, 2021 11:15 AM
cliveb
Feb 13, 2018 07:01 AM
EZDriver
Sep 29, 2014 04:24 PM
