2002 XK8 Code P0332
Old Feb 15, 2025 | 11:31 AM
Drdaffy's Avatar
Default 2002 XK8 Code P0332
I have read that the 0332 code is a knock sensor.
Anyone have experience with this?
Easy to get to?
Is part available?
Other reasons for code?
Just had the transmission valve body replaced with a used one that I had installed the Transgo pressure regulator. Any relation to this for the code?
Thanks for any insight on this.
Old Feb 15, 2025 | 02:04 PM
motorcarman's Avatar
'B' bank (bank 2) KS fault.
You can replace them with a 13mm socket and 'E' Torx socket through the intake 'runners' and snake the wire under the manifold.
Old Feb 15, 2025 | 09:00 PM
zray's Avatar
Easy to get to?
Is part available?
XK8 or XKR ?
With your XK8 easy to get to knock sensor
With a XKR not so easy. The supercharger has to come off first.
Z
Jon89
Jan 29, 2019 11:44 AM
Wewillbfree
XJ40 ( XJ81 )
Apr 25, 2017 06:22 AM
MDMike
Dec 3, 2015 06:34 AM
bharvey622
Sep 13, 2013 05:10 AM
