2003 U-joint grease question
Old Jul 20, 2015 | 08:37 PM
brgjag's Avatar
Default 2003 U-joint grease question
Can the u-joints on my 03 XK8 be greased, do they have nipples to attach grease gun to so I can grease the rears? My shop when they had the car said they can be greased, when I asked about it after they finished the car he claimed he never told me that. So it was not done. My googling of it says otherwise if I read it right? Can I do it myself.
Old Jul 20, 2015 | 08:53 PM
Gus's Avatar
Gus
Yes you can do this but you will need to get the car on jcak stands or on a lift.
Link http://jagrepair.com/images/AutoRepa.../Halfshaft.jpg
Next time look on my page!
Old Jul 21, 2015 | 03:40 AM
dibbit's Avatar
What type of grease should be used? I'm planning on using my marine 2-4-C grease which is in my grease gun.
Old Jul 21, 2015 | 08:45 AM
brgjag's Avatar
I thought there was a place at the wheel hub also that could be greased???
Old Jul 21, 2015 | 08:48 AM
fmertz's Avatar
I went with this: Mystik JT-6 High Temperature grease
Found it at Walmart of all places...
Old Jul 21, 2015 | 09:31 AM
fmertz's Avatar
Basically, both ends of each drive shaft can be greased (4 nipples total). They are kind of recessed but can be reached with a normal grease gun. They are at 90 deg from each other on each drive shaft.
U Joint on the differential side
U Joint on the wheel side
Old Jul 8, 2017 | 04:51 PM
laguillotine's Avatar
Hi all,
I did this today, then thought afterwards is there one to grease on the drive shaft too. I can't seem to find an answer anywhere so I was wondering if anyone knew? saves me jacking up the car again!
Old Jul 8, 2017 | 08:40 PM
Gus's Avatar
Gus
I do not have one on my drive shaft.
Old Jul 8, 2017 | 08:49 PM
RJ237's Avatar
Only the four on the u joints, and just about any grease will do.
Old Jul 10, 2017 | 07:22 AM
oldmots's Avatar
I just keep my grease gun filled with Mobil 1 synthetic grease, which is red. It is waterproof and long lasting.
Old Jul 11, 2017 | 10:51 AM
jeremys's Avatar
Question Grease nipples
Can anyone tell me if there is a specific size adapter to grease joints just purchased floor jack and stands and that looks like something that should be addressed and will purchase gun when know if there is a specific size for Jags
Thanks in advance
Jeremy
Old Jul 12, 2017 | 03:11 AM
woox4's Avatar
Standard size does it. A needle tip can be useful too.
Old Jul 13, 2017 | 01:52 PM
jeremys's Avatar
Question U-joint nipples help
Ok so got my new floor jack and Lucas grease gun jacked up car from standard position placed jack stand crawled under but gun Assembly on end of flex hose seems or be to big to gain access to the nipple, can't get a straight shot at it .
What am I doing wrong? Do I have to jack up from another spot to raise wheel after chasie is in the air or get a shorter nipple for the grease gun? I'm usually pretty good at doing most work myself but this has me beat for now if the nipple assembly on the end of the hose was an inch shorter would not be having this issue. Any advice accepted I know it can be done.
Thanks all
Jeremy:icon
Old Jul 13, 2017 | 02:01 PM
Gus's Avatar
Gus
Are you attempting to do this with the fittings facing the aft of the car?
Old Jul 13, 2017 | 04:27 PM
jeremys's Avatar
Hi Gus
On drivers side wheel, about 195 degrees seems closest, down, slightly to the back but my tip to long.center hub nipple down same issue
Old Jul 13, 2017 | 05:10 PM
Gus's Avatar
Gus
It is a little tight but achievable.
Old Jul 13, 2017 | 06:49 PM
kstevusa's Avatar
This job seems much easier when I used a Needle End attachment mounted on end of flex hose. The needle end depresses the ball and sends grease direct into the zerk. Also have used a cone end adapter that fit well on CV joints on 4WD vehicle.
Old Mar 22, 2025 | 12:06 PM
LMG's Avatar
LMG
I went to grease my U-joints today and found I couldn't get my regular grease gun coupler to attach to the outboard nipples properly because of the angle the nozzle has to sit at to clear the hub. Bought both a needle nozzle and a narrow body coupler from my local parts store, but the needle didn't work for me either (tip too large to push the ball out of the way). The narrow body coupler was perfect though. I used this one, just thought I'd share.
Old Mar 22, 2025 | 02:44 PM
Dr. D's Avatar
FWIW, I use a Lock N Lube coupler.A little pricey, but no mess, the grease goes in where it belongs. I have plenty of fittings to justify it.
Old Mar 23, 2025 | 08:10 AM
JimmyL's Avatar
I jack up the car and remove the wheel one side at a time. Then you can rotate the hub to get at the grease fittings.
Shawn Svacha
Nov 4, 2019 02:47 PM
kevinl
Oct 31, 2019 06:15 PM
neruda
Oct 18, 2015 01:19 PM
Richard_gib
Sep 12, 2015 07:08 PM
OkieTim
Sep 8, 2015 04:48 PM
