2003 XK8 - CD Player No Longer Works
Old Aug 26, 2020 | 10:56 AM
Zafu's Avatar
Default 2003 XK8 - CD Player No Longer Works
Good day all,
I own a 2003 convertible XK8 with original stereo parts. For a few years, the CD player would occasionally pause and start again and it appears its finally given out. I assume the 6-CD changer in the trunk is a combo of changer and player.
Can you please suggest if it's best to replace it with a like-part, or call a Car Stereo store and find something compatible; if so, what would that be?
Assuming all I have to do is find a OEM or used part (CD Changer) , is it easy for a lay-person to install, or should I have a stereo store do it?
I called my foreign car service place and they wanted $165 to diagnose the problem. That seemed absurd to me, but perhaps it's more complicated than it appears. The radio works and when I try to play a CD it tries to load but can't. So to spend $165 to "diagnose" this seems nuts. After I nicely pushed back on that idea, they ended up telling me that the part is no longer available from Jaguar and that I should go to a Car Stereo store and get another part and remind them that they need to synch the new part with the radio.
Your insights on how to approach this would be greatly appreciated. I love this car and miss my music.
Best regards,
Zafu
Old Aug 26, 2020 | 11:38 AM
Six Rotors's Avatar
I just bought a CD Changer for my X350 for $60 US from ebay. It works very well. There are several for sale currently on ebay for your car and you should be able to buy one for less than $100. Just make sure that the one you buy has the same part number as your existng unit and it will be plug and play.
Old Aug 26, 2020 | 12:03 PM
Zafu's Avatar
Originally Posted by Six Rotors
I just bought a CD Changer for my X350 for $60 US from ebay. It works very well. There are several for sale currently on ebay for your car and you should be able to buy one for less than $100. Just make sure that the one you buy has the same part number as your existing unit and it will be plug and play.
Thank you for this. Do I need to remove the CD Changer to get the part number, or is the part number something I can look up since I'd expect it to be the same for all 2003 XK8 Jags... ??
I don't know how to remove the changer, which is why I'm asking. What I would do is buy the replacement part and then have a local store install it for me.
Thanks. -Zafu
Old Aug 26, 2020 | 12:15 PM
tberg's Avatar
Before you buy anything, eject the cassette in the trunk, and shove it in again. it has happened to mine several times, and this has usually fixed it.
Old Aug 26, 2020 | 01:10 PM
MarkyUK's Avatar
CD optical head cleaner first, appreciate it's 17yrs old
2nd try asking in the x100 forum and not this one for the more modern x150
Old Aug 26, 2020 | 01:27 PM
Originally Posted by Zafu
..... I own a 2003 convertible XK8 with original stereo parts. .....
Welcome to the forums Zafu,
I've moved your question from X150 (2006-2014) to X100 (1996-2006) forum. This is the place to post technical questions about your model.
Old Aug 26, 2020 | 05:27 PM
Six Rotors's Avatar
The part you need for your 2003 XK8 is LNC4160AA. Same part was used in the XJ8 .If you feel uncomfortable installing it your self have your regular shop do it.
Old Aug 26, 2020 | 06:34 PM
Johnken's Avatar
Zafu,
1. Easy enough to replace. I'm sure you can do it if you choose that route.
2. Last I looked these are common on ebay. I believe they used the same CD changer all X100s 1998 through 2006.
https://www.ebay.com/itm/98-99-00-01...kAAOSwTOZfRqUy
3. I find my bluetooth adapter sounds better, is easier to use, and with Amazon prime (free downloads) I have access to 100's of artists & albums at any time.
Bluetooth addition about $140 and 60 minutes to install. If you can use a soldering iron and a screwdriver, you can install it yourself.
Bluetooth I describe adds hands free phone too.
If you want help changing the CD changer or installing the Discount Stereo (store where purchased) JagHD- CD bluetooth (model name) just ask.
John
Old Aug 27, 2020 | 03:40 PM
David Dougherty's Avatar
Default My CD failure cure
My CD player on my 2000 also failed. The cartridge was stuck in the player. I pulled the unit out and opened up the case. After 20 years of Florida heat the lubrication was dried out. I lubricated the mechanical drives and that cured the problem.
Old Aug 30, 2020 | 01:50 PM
steven300's Avatar
my 2001 xj8 CD player stopped 2 weeks ago as well. i realy miss it as i don't like ads on the radio, it shows no disc. i pulled cartridge out several times and still the same message.
TomCavallo
Oct 2, 2014 11:36 AM
jeronimojaxon
Jul 25, 2012 09:05 AM
Steve W
XJ40 ( XJ81 )
Jan 30, 2012 09:43 PM
dancingmullah
Audio/Visual Electronics
Jul 23, 2010 12:49 AM
charm11
Jul 22, 2010 03:31 PM
