2003 XK8 PS Dipstick read??
Old Mar 5, 2015 | 08:15 AM
brgjag's Avatar
Default 2003 XK8 PS Dipstick read??
Thought I would check mine. The stick has not worded reading levels, just two raised lines on it. I assume if you are at the top line you are good?
Old Mar 5, 2015 | 09:39 AM
gatekeeper's Avatar
Your correct, oil level is full. And, anywhere in between the lines is ok too.
Old Mar 5, 2015 | 10:23 AM
RJ237's Avatar
While on the subject, a regular maintenance item should be to change the atf in the PS reservoir when you change engine oil.
Old Mar 5, 2015 | 10:34 AM
brgjag's Avatar
I have owned so many cars, most with some miles on them and have never changed out fluids in PS, Brakes. I can say I have never had issues as a result of not doing so.
Old Mar 5, 2015 | 05:57 PM
jamdmyers's Avatar
Quick search, this would apply to PS as well
A feature of brake fluid not commonly recognised is that it deteriorates over time. The main reason for deterioration is that brake fluid is hygroscopic, that is, it absorbs moisture from the air.
Because of the heat produced by friction when brakes are operated, brake fluid is designed to have a high boiling point, typically about 265°C / 509°F. Any moisture absorption could find this temperature reduced to a mere 140°C / 284°F over a period of two years. At this level, any period of sustained braking could produce enough friction to bring the fluid to the boil, where it vapourises, leaving the driver with little or no brakes.
Unlike engine oil which should be changed according to the distance driven, brake fluid deteriorates not with distance but with time. It continues to absorb water even when the vehicle is stationery. Most vehicle manufacturers recommend regular brake fluid changes on a time basis, e.g. every year. Unfortunately, such recommendations are not always followed and independent surveys have shown that many vehicles have dangerous brake fluid in them.
aholbro1
Dec 29, 2024 06:46 PM
Adam Lueb
Sep 28, 2015 02:54 PM
OkieTim
Sep 8, 2015 04:48 PM
David Thompson
Sep 3, 2015 07:48 PM
OkieTim
Sep 2, 2015 12:48 PM
