2003 XK8 swapped trans now P610 code
Old Jun 15, 2021 | 12:19 PM
Jandreu's Avatar
Default 2003 XK8 swapped trans now P610 code
2003 XK8 swapped trans now P0610 code. Now what, can the TCM from the orginal trans be swapped to the replacement trans to solve this. Any other resolutions.
thanks for your
Old Jun 15, 2021 | 04:36 PM
michaelh's Avatar
Do you have access to WDS?
I wonder if swopping the TCM would need the 'adaptations reset' performed anyway, since it will have learnt from the old transmission?
Hopefully someone with trans experience will jump in here
Old Jun 15, 2021 | 05:24 PM
Jandreu's Avatar
@machaelh tks yelp most likely but over time it should still relearn. Don't have IDS which is the problem.
deelli
Sep 22, 2020 01:10 PM
blk05coupe
Jul 30, 2013 03:47 PM
megalosdog
37
Oct 26, 2011 01:00 PM
brgjag
May 13, 2009 01:27 AM
