2004 Jaguar XKR Tow Hook
Old Dec 28, 2020 | 06:42 PM
motorcarman's Avatar
FROM VIN A30645 is supposed to be the M16 x 3.0 LH thread tow eye.
The older VW Jettas and the S-Type is also the M16 tow eye.
Old Dec 28, 2020 | 06:54 PM
Anglicomarine0326's Avatar
With Motor man's knowledge about this subject, and based on VIN# I was able to quickly locate and purchase the correct eye on Ebay for only 18 dollars shipped! As a 40 year British car fanatic/owner, and currently own a 91 XJS V12 convertible and 2003 XKR convertible....Never have a seen a more confusing subject for a really simple part. I look forward to never having to use it here on Cape Cod Massachusetts.
Old Dec 28, 2020 | 08:05 PM
zray's Avatar
Originally Posted by Anglicomarine0326
”...... I look forward to never having to use it here on Cape Cod Massachusetts.
this is all very interesting, but your photos begs the question, is Nana’s ice cream worth the drive from Oklahoma ?
Z
Old Dec 28, 2020 | 08:12 PM
Z
Too funny, it has very good ice cream and candy. We have a very active British Car Club here. A big 3 day event show every fall. Come visit!
Old Dec 28, 2020 | 08:21 PM
zray's Avatar
We will have to make the trip. For the ice cream of course, and to see some family history; My SO’s distant ancestors once owed Martha’s Vinyard back before the civil war. I’m sure it was just a mosquito infested swamp back then.
Z
PS. my ‘02 XKR VIN ends in A24583 and of course the tow bolt is missing, the rest of the “kit” is there though. Still Not sure which bolt to order or from where
Old Jan 8, 2021 | 03:43 PM
Sentinelist's Avatar
Originally Posted by XK8 Rebel
Found another alternative for a replacement tow hook. I noticed mine was missing out of my 2003 XK8 a couple of weeks ago. Finally figured out mine was the M20 x 2.5 version. I went to the salvage yard today, but every Jag I checked was either missing its tow hook or had the wrong one for my needs . So I was checking out some different vehicles I had read might have the same thread specs. No luck on the VW or Mazda. Finally found one that was a perfect fit. It came out of an 2007 Hyundai Accent of all things! Works on the front and rear and fits perfectly. The best part was the cost $3.25! Can't even buy an eye bolt for that!
And it fits in the jack kit under the spare with only very minor alteration. Less than an inch of Styrofoam was removed to allow the longer shaft to fit.
Kit w Accent tow hook
Genius! This worked for me. Got it on eBay for under $20 used and is a perfect fit on my 2000 XKR. Thanks!
Old Jan 10, 2021 | 02:06 PM
STLTHMSTA's Avatar
I just ordered a couple of tow hooks from McMaster Carr, an industrial supply house here in the US, if you're not familiar. 150mm long and I'm trusting you guys on the M20 x 2.5 being the right size. I checked my car and low and behold it's not there. Where in the heck are these things going??? Is it too hard to put it back??
I'll let you know when they arrive. TM
Old Jan 10, 2021 | 02:39 PM
  #28
zray's Avatar
Tow truck drivers are collecting them for the next job.
Z
Old Jan 13, 2021 | 05:59 AM
STLTHMSTA's Avatar
Well, my eyelets came and they do not fit. I couldn't find a way to measure the hole as it is recessed a bit and the hook would require a bit of shaft to get the eyelet out oil the open.Bottom line is M20 is too big, I should have paid closer attention to the above post advising M16. I'll see what I can find. BTW, the industrial eyelets are too short, there isn't enough shank to reach the recessed hole. My serial is A30811.
Old Aug 12, 2024 | 04:36 PM
  #30
LMG's Avatar
LMG
I realized the other day that the tow eye is missing from my 2004 XKR, and I just confirmed (with a bolt) that it is an M20 x 2.5 RH thread. My VIN is A37XXX, so I think the statement quoted below that it should be M16 from VIN A30645 is not correct (unless I'm misreading the context).
Just thought I'd share
Old Aug 15, 2024 | 11:27 AM
  #31
LMG's Avatar
LMG
Thanks for this, I ordered a Hyundai hook too, perfect fit in mine!
Old Feb 9, 2025 | 10:41 AM
  #32
phillipreid's Avatar
I agree with the suggestion to check the actual car; I just found my 16mm towing eye mounted in the front of my new 2006 XK8 VE. Been there so long it had road abrasion on it! But my friend with a 2003 has a different thread on his.
Jst2gtby
Apr 11, 2026 12:02 PM
car5car
Sep 26, 2018 03:55 AM
rjallen
Jun 27, 2018 01:56 PM
Narda 1
Dec 30, 2015 01:25 PM
phaelax
Sep 28, 2012 08:55 PM
