2004 XK8 Transmission problems
Old Jun 19, 2013 | 09:28 AM
westy's Avatar
Default 2004 XK8 Transmission problems
New to the forum...a great resource! When my 2004 XK8 transmission is in 6th gear and I start to go up a long slight incline, I press the accelerator slightly to go up the incline and I feel a shaking in the car (similar to how a car with a manual transmission would react if in too high a gear). It seems like the transmission should be downshifting to get up the incline, but does not do so. I have to really give it some gas before the transmission downshifts to get up the incline. There is also a "groaning" noise that comes from the drivetrain when I am pressing the accelerator in order to maintain normal driving speeds on roads and highways. On a whim, I switched to sport mode and the problems were not as prevelant, but they still occured. Any thoughts as to what the issue(s) might be?
Old Jun 19, 2013 | 11:38 AM
Gus's Avatar
Gus
Do you have any OBDII codes or Restricted Performance, Fail Safe or Transmission problems indicated on the dash?
Old Jun 19, 2013 | 12:02 PM
Welcome to the forum westy,
I've moved your post to the tech section, don't forget to post an intro in the new members area.
Old Jun 20, 2013 | 10:35 AM
westy's Avatar
Default Transmission
I have no codes or messages indicating any problems with the transmission or engine. I do notice when I accelerate quickly from 35 mph up to 70 mph that the vehicle seems to feel like it "surges" as I accelerate...I notice a very slight dip in the rpm's on the tach as this happens. Thanks!
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
