2004 XKR Headlight Leveling Linkage
Old Jul 2, 2020 | 08:17 AM
jurczak1's Avatar
Default 2004 XKR Headlight Leveling Linkage
Does anyone know where I can get the linkage to connect the headlight leveling switch to the lower bracket for a 2004 XKR? I can't seem to find the linkage as a separate part. US sources would be good but any source would help. If this question has been asked before, I couldn't find in the posts. Thanks for any help.
Linkage is number 1
My 2004 XKR
Old Jul 2, 2020 | 08:50 AM
Jon89's Avatar
If you cannot find one as a standalone part, a good metal shop may be able to fabricate one for you out of an appropriately-sized sway bar end link (which that part in the above drawing surely looks like)....
Old Jul 2, 2020 | 09:19 AM
michaelh's Avatar
Hi jurczak1
It's one of those "You will have to buy the whole item, sir. That part is not available separately"...
Member PKWise managed to engineer a replacement. It's for the rear, but I imagine that something similar would work at the front:
https://www.jaguarforums.com/forum/x...4/#post2246786
or you might find one in a breaker's yard.
Old Jul 2, 2020 | 09:21 AM
jurczak1's Avatar
Thanks, Jon89, that's a good idea. It is much smaller than a sway bar, but I think I could make something that can do the job if I can't buy a replacement part.
Does anyone have the measurements of the linkage from center of ball to center of ball or a drawing of the part? The repair manual doesn't show the linkage and I don't have the original part.
Old Jul 2, 2020 | 09:25 AM
jurczak1's Avatar
Thanks, michaelh. I actually have a second rear one. I accidentally ordered it thinking it was the front one. I'll try and cobble one up and hopefully I can make it work.
Old Jul 6, 2020 | 03:12 AM
PKWise's Avatar
- as per michaelh mentioned - I lost same link on rear and couldn't get a replacement either. Ended up buying mini Rose joints instead (stainless).
Old Jul 17, 2020 | 09:28 PM
giandanielxk8's Avatar
I finally inspected mine today. I didn't just loose the linkage, I also lost the plastic linkage to the sensor. I rotated it by hand and the sensor still works. It was in the highest position that must be why I couldn't see very well at night. I set it to its lowest position. I think I will have to order the entire sensor. Or maybe I can come up with some solution...
Wide_Tyres_2
Sep 27, 2016 11:05 AM
Narda 1
Dec 30, 2015 01:25 PM
stanigu
Sep 28, 2013 09:03 AM
cadmium
Apr 29, 2012 04:43 PM
sannabhoy
Dec 30, 2008 07:06 PM
