2005 base convertible front sway bar size
Old May 29, 2020 | 03:54 PM
wymjym's Avatar
Default 2005 base convertible front sway bar size
I was going to order some poly front sway bar bushings for my 2005 xk8 but wanted to be certain of the correct size. I measured the straight section below the radiator and it measures 25.65~25.83 dia, I then measured the short straight section toward the end of it read 25.4~25.6.
I assume the mounting point is not machined and must fall somewhere within these measurements.
Do I have what is considered a 26mm front bar?
HELP!!!!!
Old May 30, 2020 | 07:38 AM
kstevusa's Avatar
Cked on Google and they indicated the Front Sway Bar was 26mm dia. Just over 1 inch in non metric. Seemed to be same in a FHC..
kazi
Nov 15, 2019 08:57 PM
JaguarSpecialties
May 20, 2014 12:24 AM
GordoCatCar
Apr 24, 2013 12:34 PM
Sqeeter91
May 9, 2012 10:57 PM
