convertable roof
Old May 30, 2020 | 11:43 AM
98 shadow's Avatar
Default convertable roof
there seems to be alot of issues with the hydraulic pressure (too high). What is the cheapest and or simplest way to correct this problem for a DIY
Old May 30, 2020 | 12:08 PM
avern1's Avatar
Follow the link below. Read the info and you can contact Gus directly. Pretty straight forward install.
JagRepair.com - Jaguar Repair Information Resource
Old May 30, 2020 | 12:24 PM
Dennis07's Avatar
Shadow,
See these links, also found in my signature line below. .zero-cost pressure reducer voltage reducer
Old May 30, 2020 | 12:26 PM
DavidYau's Avatar
Default Keep on top of hydraulics
+1 to avern1
In the construction industry, high pressure hydraulic systems are common. Common mistake is to think it’s a “leave alone, it’s working” system. They need to be worked and require inspection, servicing and careful eye.
I would use the system at least once a month (helps keeps seals lubricated) and check the condition of your hoses - 2 min job by looking behind the carpet in the RHS of the trunk. Also remove the rear seats periodically as you can easily see if the hydraulic rams are leaking.
Also R&R hydraulic fluid in the pump reservoir once every 3 to 4 years depending on use.
Not many reports of failure of the pump but it’s the electrics you need to keep an eye on.
SonofGaladriel
Dec 29, 2019 09:09 PM
Gus
May 26, 2016 05:22 PM
malc4d
Dec 11, 2014 08:45 PM
WayneCountyBill
Sep 11, 2014 07:53 AM
Simprof
Jul 5, 2011 03:31 PM
