2k XK8 NUMBER PLATE LIGHT
Old Jun 6, 2021 | 11:55 AM
Goldwing's Avatar
Question 2k XK8 NUMBER PLATE LIGHT
License plate lamps - left one works, right doesn’t...
Removing the cover was easy enough (despite the manual advising the dealer has the correct tool and I should take it to Memphis)
BUT
How do you get the bulb out?
Is it a bayonet socket, screw in, or does it just pull out?
Or is there some “trick” I’m missing?
Old Jun 7, 2021 | 08:17 AM
JimmyL's Avatar
They are supposed to pull out. Same bulb as the front marker light and the side (rear) marker lights (if you have them).
Old Jun 7, 2021 | 08:45 AM
Goldwing's Avatar
Thanks Jimmy
I couldn’t move the bulb and was afraid I’d break it causing more problems.
Knowing they pull out instead of twisting did the trick.
A little good old electrical tape on it and it came right out...
The bulbs are # 2825
The *special tool* is a small blade slotted screwdriver.
King Charles
Apr 12, 2018 06:50 PM
rf69
Jul 5, 2017 03:32 PM
Roadan
Aug 19, 2016 09:11 PM
copcardrvr
Jan 17, 2015 08:13 AM
J8levi
Nov 8, 2014 09:18 PM
