3 Raised lights 2003 XKR
Old Oct 18, 2016 | 11:09 AM
sjagerson's Avatar
Default 3 Raised lights 2003 XKR
I just brought my 2003 XKR home from Maryland. I was able to disengage my emergency brake quickly due to the forum's great contributors. However, I still have a 2 beep warning (every 5 seconds) that I can't stop. Most importantly, I have had a frantic red light (whistling, clicking and flashing) intermittently going wild on the trip home 250 miles and since then. It is located at the base of the tachometer like the other two at the bases of the speedometer and fuel/heat gauges. There is no mention of them in the manual and they illicit no messages and provide no codes. If I had another option I would have stopped the car until I could figure out what was wrong. Of course, I would still be there. I have searched the forum and found some speculation , but nothing definitive.
I have an issue with the front shocks (or shock seats) and I'm trying to find out if the battery needs to be replaced. I'm getting it inspected tomorrow and will get the battery check and replaced if needed on Thursday.
Thanks for listening.
Scott
Old Oct 18, 2016 | 11:37 AM
grantorino62's Avatar
You have 2 red icons in you tachometer assuming you have navigation. One is an oil can icon. The other is a seat belt icon. Which one is it?
Old Oct 18, 2016 | 01:14 PM
Items 17 and 15:
Old Oct 18, 2016 | 01:41 PM
Hopefully it's the seatbelt.
Old Oct 18, 2016 | 03:00 PM
03 XKR's Avatar
If it is #15 that is blinking, then the Driver's side seat belt buckle connectors may be loose or damaged, or there could be a foreign object stuck in the seat belt buckle that is not allowing it to clasp completely, or is blocking the Sensor from detecting that the buckle is clasped, and is intermittently setting off the Driver's Seat Belt Warning Light and Tone. Canned Air and Electronics Cleaner, should it be something sticky, directed into the buckle and sprayed while actuating the release button on the buckle could dislodge an object, or dissolve anything sticky that may be causing the problem.
Have you had a passenger in the car before all this began, and since it has begun? I do not know if the same light will chime and blink if the passenger belt buckle is not fastened, or the buckle is jammed or not fully disengaged from the last time a passenger exited the car. The electronics may be 'confused' if the passenger buckle is being detected as clasped, but no weight is on the seat to activate the passenger air bags.
Old Oct 18, 2016 | 03:27 PM
sjagerson's Avatar
These are not icons. They are physical protruding lights at the base of the instruments. You can run your finger over them. The middle one remains green.
Old Oct 18, 2016 | 03:29 PM
sjagerson's Avatar
Not icons, physical lights sticking up from the base of the instrument panel.
Old Oct 18, 2016 | 03:32 PM
sjagerson's Avatar
There are no corresponding numbers for the lights I'm speaking about in the instrument panel representation in the manual. They are in front of the instrument panel glass, not behind it.
Old Oct 18, 2016 | 03:37 PM
stingray71's Avatar
If you can provide a picture that would probably help other members with the diagnosis.
Old Oct 18, 2016 | 03:51 PM
dsd's Avatar
dsd
Sounds like an aftermarket alarm or radar detector.
I don't have this on my 2003 XKR
RJ237's Avatar
Aftermarket security or communication device?
Old Oct 18, 2016 | 11:29 PM
pbuck's Avatar
Probably a radar detector, perhaps an old K40 custom built-in, and the beeps and clicks would be different radar bands/laser. On the drive back, did the flashings and sounds happen when you went past stores or shopping malls (a store's automatic doors sets off x-band detects) and then it was quiet between towns? Do you have a knob mounted somewhere nearby with 3 positions (off, city, highway)? A knob that is not in the Jaguar manual, that is.
If it is a K40 you can find a nearby dealer on the website and they should be able to tell you what you have.
Old Oct 19, 2016 | 07:25 AM
sjagerson's Avatar
It may be a radar detector. I have included some pictures. It seems a little involved to mount lights in the dash for a radar detector. This may let me know what the bar might be that is affixed to the front of the grille.
Flashing at start up
Old Oct 19, 2016 | 07:38 AM
Jandreu's Avatar
Yelp, radar detector
Old Oct 19, 2016 | 12:08 PM
sjagerson's Avatar
KD40 2000 radar detector and laser jammer. All of the beeping and flashing was due to the police and the rear laser jammer being disconnected.
This drops my anxiety level by leaps and bounds!
Now if I can just get it inspected and get the shock situation worked out, I'm good for winter storage.
Thanks again to all of you. What a great support group.
Scott
cwmjaguar
Sep 6, 2016 01:54 PM
dsd
Aug 27, 2016 09:09 PM
sprk33
Aug 25, 2016 07:31 PM
papastoy
Aug 25, 2016 05:22 AM
cwmjaguar
Aug 24, 2016 09:10 PM
