3000 rpm on start
Old Apr 24, 2010 | 09:13 PM
Gus's Avatar
Gus
Not sure that I understand your question. If you start the car and YOU rev the engine it will only go to 3000rpm. The car is setup/designed to do that. If you put the car in gear and hit the accelerator the engine will go well over the 3000rpm and give you the performance you want.
If you are saying that the engine after starting it goes to 3000rpm on its own I would be very concerned and would be checking the TB and or the TBPS.
Old Apr 25, 2010 | 03:58 AM
Brian2000XKR's Avatar
Hi Steven,
Sorry, I can't help you with this problem, but I thought that I should point something out just in case you were unaware of it. FYI, these cars are trouble prone when only driven short distances. Given the opportunity, I would really try to limit that as much as possible. You might want to do a search here on the forum, as there is plenty of info on the subject. Good luck with your revving issue.
Regards,
Brian
Old Apr 25, 2010 | 07:02 AM
steve11's Avatar
ud
Originally Posted by stevenham
1999 XK8 with 55k miles .. periodically on start engine revs to 3000 rpm .. mechanics have twice "cleaned the throttle plate" which restores normal idle rpm on start for a period of time .. only to see the 3000 rpm pop up again after a few months .. car driven sparingly (1-2 times per week max on short trips usually) .. would appreciate any comments/ideas on how to restore reliability in this area .. many thanks
What is the condition of the battery? Check the battery output voltage, especially after it sits for a couple of days w/o being recharged. My guess is that it is falling below 12.1V. At this threshold (12/12.1) lots of quirky things begin to happen, one of which is - the ECU doesn't have enough voltage to keep its last shutdown algorithm alive. The startup high rev is a classic symptom when the battery has been disconnected for several hours, the ECU will reestablish all its initial sensor readings at high RPM.
08Z06
Oct 24, 2015 05:46 PM
jagtoes
Sep 9, 2015 09:56 PM
OkieTim
Sep 8, 2015 04:48 PM
1100me
Sep 7, 2015 06:26 AM
XFR_Gold
Sep 2, 2015 12:24 PM
