3D printer file repository
Old Feb 16, 2026 | 09:13 AM
Veteran: Navy
Default 3D printer file repository
Use this sticky to post any 3D files you may have for hard to find parts
Old Feb 17, 2026 | 02:52 PM
jhuertas's Avatar
We already have a dedicated thread for 3D printed models. I'm adding the three things I've made:
a) The pollen filter housing. Some XK8 models don't have it (I've owned both), but it can be installed. The gearbox cover/filter screws work very well (you can shorten them a bit).
b) Speaker covers to protect them from water inside the doors (I printed them in TPU).
c) The headlight drip rails. I'm uploading them in STEP format so they can be modified to suit each user's needs.
File Type: rar
File Type: rar
Old Feb 17, 2026 | 03:57 PM
Veteran: Navy
figured it would be easier to find the title of this thread plus since it is a sticky - will be at the top of the main page
Old Feb 18, 2026 | 08:00 PM
champir's Avatar
Default SatNav Replacement
I originally came across this Joying Head Unit Screen Mount for Jaguar XK8/XKR by Russell_S on Thingiverse ( https://www.thingiverse.com/thing:4186500 ) to suit mounting a modern touchscreen over the existing SatNav spot.
I was considering this approach however in the end I designed a plate that clips into existing SatNav unit facia to mount a Carpuride W903 unit using a modified Portable Sticker Bracket (because they sent me the wrong one).
I disassembled the Jaguar SatNav and retained the plastic surround with the buttons as they are a little visible behind the unit. I used knurled insert nuts and M3 hex bolts to secure the mount.
Printed it in ABS to withstand the harsh Australian summer temperatures. I have been happy with both the unit and the mounting solution as it has remained functional and adds carplay to my car.
I was planning to tap into the audio out of the unit and feed it into the plugs available from the old SatNav but haven't gotten around to it as yet. If I can find some compatible plugs/sockets used there I might give it a go soon.
File Type: zip
Old Feb 19, 2026 | 04:01 AM
champir's Avatar
I made this replacement mount for the seat control Xk8 module which is prone to cracking.The module is bolted under the front of each seat in Jaguar X100 models 2001-2005. Modules are part number LJE2160AB/XXX.
Replacement lids are available (Part number C2N3565) however I decided to print my own.
Jaguar TSB 419-17 describes the problem further.
https://www.thingiverse.com/thing:4338477
File Type: zip
Jason1941
Dec 14, 2017 06:16 PM
kenatofc
May 30, 2017 07:03 PM
VanJaggerstien
Feb 21, 2013 03:36 PM
attaboy
May 12, 2010 02:59 PM
nilocp
Nov 11, 2009 06:40 PM
