4.2 xkr brembo brakes & calipers
Old Aug 22, 2024 | 01:37 AM
Sethharttt's Avatar
Default 4.2 xkr brembo brakes & calipers
Hi there! Does anyone know where to get replacement brakes and calipers for the 4.2 models. Thank you so much!
Old Aug 22, 2024 | 09:02 AM
fmertz's Avatar
Can you clarify what you are looking for? These Brembo calipers are hard to find and pricey if you can find them. They are unfortunately not shared with the S-Type R. There is compatibility with the older X308 XJR I believe. If you have a set, best is to look at rebuild kits, etc, if necessary.
Rotors/disks seem generally available. I went with RockAuto, but there are other options.
There are options for pads. The Jaguar/OEM I have are very dusty (they came as "loaded" calipers).
Best of luck, keep us posted.
Old Aug 23, 2024 | 11:31 AM
Sethharttt's Avatar
Hey there! I need replacement Brembo pads and rotors. Would you happen to have the links to any?
Charbinjr
Sep 2, 2019 08:39 PM
BruceTheQuail
Jan 27, 2015 08:24 PM
cpm53
Oct 21, 2011 06:16 AM
crocodile62
17
Apr 13, 2010 03:00 AM
