forgive me for stating the obvious, but why not attach a degree wheel to the crankshaft ?
You will not get repeatable accuracy by trying to measure degrees of crankshaft rotation by measuring the millimeters of piston movement instead.
That’s why valve timing has always been expressed in terms of crankshaft degrees of rotation, not by measuring piston movement.
Z
There are specific tools for this job which i have, i order to find where this tool is put into the ring gear, it helps to know approx where 45 ATDC is all i am doing is trying to find this hole in the first time or two of crawling under the car.
l dont know about the obvious, but probably the unnecssecery due to seeing these tools i have used in every manual i have seen, and none with a degree wheel
This is the way the manual says to do it. so this is the way i will.
Some of the current Tat; along with many antique outboards, stationary engines, generators, marine engines and with a bit of luck, soon a Bren gun carrier
I just get under the car and turn the engine until the timing slot appears in the 'window' next to the CKPS hole where the crank lock tool goes.
You can pry on the torque converter with a large screwdriver or get a long handle 'flex-ratchet' with a 24mm socket on the damper.
If you find the cams 180 degrees out, rotate the engine around again to get it right.
Install the crank lock tool and set the cams/chains, etc.
Or you can just measure 22mm from the top of cylinder #1 on the downward stroke which will put you bang on or within a hair as this is where 21mm get you.
Do it in one, no degree wheel, wobbly extensions or any other performance.
