97 xk8 cold no start with electrical clicking
Old Oct 29, 2013 | 12:54 AM
Garywrx's Avatar
I checked the fan and yes it does work. I wondered about a previous repair because the ecu has "guarantee void if broken" seals on both sides. Since any thought of a warrantee or guarantee are long gone I took it apart anyways. I called a couple jag specialist in my area and none of them seemed eager to even touch the car one flat refused while the others said minimum $330 up front to start diagnosis. I just wish I could substitute a known good ecu. I will keep digging into the electrical schematics and try to explore other paths. Any other ideas let me know.. Thanks for all the help so far.
Old Oct 29, 2013 | 06:56 AM
WhiteXKR's Avatar
Bad solder joints often have temperature sensitivity. I suggest you use a 15-25 watt iron and fine gauge 37/63 flux core solder (available at Radio Shack) and reheat and add a bit of fresh solder to the joints on that transistor and any others that looks suspect. Heat the joint for about 5 seconds then add the solder to the joint, not the tip of the iron.
Old Oct 29, 2013 | 07:57 AM
Gus's Avatar
Gus
How does one verify that that fan is working properly? What activates it?
Old Nov 4, 2013 | 12:14 AM
Garywrx's Avatar
If you gently lift up the ecu you can see the fan running. As far as what activates it and at what time I have no idea. It looks like ecu doctors will test the ecu for $50 I seriously considering it. I have gone over the solders with no change I have a few other things I'm going to try and I'll get back.
Old Dec 27, 2013 | 10:05 AM
khXK8's Avatar
A freind had a similar problem with XK8 98, and found that the oil level was low. Worth a quick check for a simple solution.
Old Dec 27, 2013 | 11:55 AM
RJ237's Avatar
The fan runs when the ignition is turned on.
99xk8guy
Sep 29, 2025 10:51 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
laserguy
Sep 3, 2015 02:02 PM
