97 XK8 engine problem
Old Apr 28, 2013 | 07:40 PM
paulab's Avatar
Default 97 XK8 engine problem
My car goes into limp mode and has the following codes; P0351, P0354, P0356, P0357 and P1367. This happens right after start up. Tried switching modules, got same codes. I need some ideas please .
Thanks, Paul
Old Apr 28, 2013 | 07:49 PM
jaglover922's Avatar
Try replacing the ignition coils that are indicated by the fault codes. It looks like cylinder 1,4,6,7. Number one coil is the first close to the drive belt on the passanger side of the engine I believe. Number 4 would be the last coil near the firewall on the passanger side. 6 and 7 would be the middle coils on the driver side. Also do a hard reset and clear faults and see what happen. Put new spark plugs too, if you already haven't. If you have oil in the spark plug tubes, Replace the valve cover and spark plug tube gaskets.
BrentGardner
29
Dec 16, 2024 12:13 AM
tberry6686
Sep 2, 2015 05:19 PM
tony bosco
Sep 1, 2015 02:06 PM
nelsonht
Aug 30, 2015 06:01 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
