97 XK8 Heater not working
Old Apr 12, 2008 | 09:11 PM
mlewisfwa's Avatar
Default 97 XK8 Heater not working
Hello to all,
I'm a new Jag owner, '97 XK8, convertiblew/47k miles. I've made some repairs already; rt front wheel bearing, rt lower ball joint, idler pulley, both front shocks, belt, front brake rotors, pads and of course the cup holder. Before I start on the heater not working, I want to ask if anyone has had this problem. The heater only blows warm air while I'm sitting still for a while. Once you start driving, it blows cold air. I've checked to see if the heater pump is running and it seems to run. The inlet hose to the heater pump is hot and the outlet line is cold. Could the impeller on the pump be broke, heater core clogged? Any ideas?
Old Apr 12, 2008 | 10:11 PM
JagtechOhio's Avatar
Default RE: 97 XK8 Heater not working
Greetings,
I think your last idea is the correct answer, these heater cores do clog. I've read more than once about owners having them replaced, and perhaps that is necessary in extreme cases. The few I have dealt with on XK8 were satisfactory after repeated flushes. Low pressure air allow so helps, and you may want to mix up a strong batch of Prestone radiator flush, fill up just the disconnected heater with it, and let it sit for a day to help by chemically breaking down some of the deposits.
Old Apr 13, 2008 | 12:03 AM
Jack Rabbit's Avatar
I've found the perfect answer to all my '97 XK8 troubles.
Ignore them and they go away!
Power surge/stall issues. Reflashed the TB under a recall notice but it didn't cure the root problem. Eventually it cured itself.
Faulty gas gauge. Cured after a few runs.
Faulty speedo. Cured after a few runs.
This car is programmed to mess with your head in an attempt to get you to throw money at it. Unless it is dead in the water, a situation for which I have AAA, I suggest giving it the cold shoulder.
It hates that! Eventually, it will bored with taunting you and go back to running normally!
Old Apr 13, 2008 | 12:21 AM
In that case, I hope my floor mat business picks up....
Old Apr 13, 2008 | 09:19 AM
mlewisfwa's Avatar
Thanks Jagtechohio,flushing will be my first step. I also noticed a little coolant leak around the thermostat housing cap. I have found replacement aluminum thermostat housing and was wondering if you would recommend replacing the housing with aluminum?
And thank you Jack Rabbit, maybe I’ll just turn my head as I walk be for a while, maybe I’ll get her attention.
Old Apr 13, 2008 | 10:48 AM
FactoryJaguarTech's Avatar
Some people swear by the aluminum housings. I personally have never tried it.
Old Apr 13, 2008 | 11:01 AM
jag_genius's Avatar
post a link
Old Apr 13, 2008 | 11:38 AM
One of the forum vendors motor cars LTR has them.
Old Apr 13, 2008 | 12:10 PM
test point's Avatar
I installed the aluminum one on my 2000 XK8. Since the aluminum is less cost than the OEM plastic one, if you need to replace it is a no-brainer. Left it bright but considered painting it. Once you take it off you will see that the plastic is simply painted black. Getting the rear bolts off is a real test. You will have to grind down a socket both in length and diameter to be able to break them loose. I think I can stillfind mine and will mail to you if you decide to replace. That's a once-in-a-lifetime tool. Send a PM if you want. Grind a blade screwdriver slot in the bolts to run back down. The multi-outlet fixture in front of the housing is supposed to be available also in aluminum.
tp
Old Apr 13, 2008 | 01:22 PM
Here here for that, but I'd make sure that it isn't just a common leak from a bad cap. The retaining ring for the seal comes apart, and then the seal doesn't make good contact with the top of the neck. It's like a $7.00 cap, I don't even re-use them anymore.
Old Apr 13, 2008 | 05:56 PM
And you can use an 8mm crows foot for the bolts. When you reinstall, use two bolts from the t-stat cover instead of the housing bolts. They are a little shorter and work perfectly.
Old Apr 23, 2008 | 09:02 PM
mlewisfwa's Avatar
Thought I'd follow up, I replaced the thermostat housing, stat and cover today with the aluminum unit, bought from http://www.motorcarsltd.com/. Also flushed out the heater core. Replacing the housing and cover went very well. 8mm crows foot was the ticket. When we flushed the heater core it was very obvious it was plugged. you should have seen the mess.....Heater works well. Attached are some pics all back together
We are getting there, a couple of more weeks, we'll have it where we want it......
Thanks for the help.....
[IMG]local://upfiles/3685/3F79BC4220554AD98079CF4FD5739BEF.jpg[/IMG]
[IMG]local://upfiles/3685/997E5ACB7DB9427EB805041B0FE0F588.jpg[/IMG]
Old Apr 24, 2008 | 05:55 PM
lockgirl's Avatar
I was going to suggest you forget about the repair and just move to South Florida! I don't even know if my heater works! [sm=smiley36.gif]
Thanks for the pics and follow up
Old Apr 24, 2008 | 07:22 PM
Lockgirl, where in S FL?
You wouldn't believe how many people we get in the summer time complaining of no heat. Its crazy.
Old Apr 24, 2008 | 07:23 PM
jag_genius's Avatar
lol really.. i m still amazed about the seat heaters.. lol.
Old Apr 24, 2008 | 07:26 PM
Lol Genius. Try explaining the temp correlation to an 80 year old that wants the seat heaters coming on at 70 degrees ambient.
Old Apr 24, 2008 | 07:32 PM
jag_genius's Avatar
lol we sometimes.. wire in volvo stats.. to come on at a hotter temp.. only for extremly **** customers.. lol
Old Apr 24, 2008 | 08:31 PM
Can you PM the details of that?
Old Apr 25, 2008 | 07:35 PM
jag_genius's Avatar
ill see if i can get the part number for the volvo themostats for monday..
Old Apr 25, 2008 | 08:42 PM
