97xk8 not starting
Old Apr 5, 2010 | 09:51 PM
rabbits2's Avatar
Default 97xk8 not starting
I have a 97XK8 with 47,000 miles, I start it about every 2-3 weeks. Most miles are highway. When I tried to start it yesterday, it fired and then stalled, then it just turned over, and only seemed to slighlty fire but not come close to starting. I thought it could be flooded ( the dealer told me once that you could "flood start" by holding the gas pedal 1/2 way to the floor and cranking it for 30-45 seconds 2 or 3 times), but that did not seem to work. I the just let it sit overnight but again it does not start, although it seems to try.
Any ideas would be appreciated.
Old Apr 5, 2010 | 11:51 PM
DpezXK8's Avatar
Had the same problem a while back. Make sure you battery is fully charged. Even though it may seem to crank OK try it anyways.
Old Apr 6, 2010 | 04:59 AM
test point's Avatar
My view of the 'flood start' procedure is to hold the throttle fully on the floor while spinning the engine several 30-45 second sessions. Full throttle cuts off fuel preventing further flooding. Wait a minute or two between to allow the starter to cool. Then try it at half throttle.
The battery will indeed spin the engine at a voltage below what is required by the electronics causing all sorts of issues.
That doesn't work try here:
https://www.jaguarforums.com/forum/s...ad.php?t=30792
Old Apr 6, 2010 | 07:21 AM
Gus's Avatar
Gus
If your car started and then died I would be checking your fuel pressure first because that is what it sounds like to me.
Old Apr 6, 2010 | 09:55 PM
BurgXK8's Avatar
How's your plugs? Check for carbon - or worse, oil - build up.
Old Apr 6, 2010 | 10:05 PM
Jag69's Avatar
Default 97XK8 Not Starting
I am the last person to diagnose the problem as there are many more competent mechanics on this forum...
However...same symptoms on my car after it sat for 2 weeks. it was the fuel pump. About a $800 fix.
Old Apr 6, 2010 | 10:07 PM
DaleD's Avatar
From: Marin County, CA, USA - Just north of San Francisco
I had the same symptoms - Fuel pump(s) - fortunately under warranty. DaleD
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
