98 Jaguar xk8 Window problems
Old Nov 30, 2010 | 07:49 AM
test point's Avatar
Take your car to an auto parts store that will do a charging system/battery test for free. Sounds like a failing battery even though the other window works.
The window motors draw a lot of current, as in a 30A fuse, and the driver window may be binding some. Next will be a door panel removal and check for loose bolts or rivets.
Let us know.
. . . . and welcome to the forum!
Old Nov 30, 2010 | 02:06 PM
Jag13cat's Avatar
Default Window Adjustments
If you haven't already:
Go to Sticky: FAQ; scroll down to Window Reset & Related Battery Voltage, near the bottom of the FAQ section.
There are a number of threads regarding window adjustments and other thought starters about window performance. This may help you with diagnosis.
msdg137
Sep 16, 2015 06:24 AM
24ktairman
Aug 30, 2015 10:25 PM
Khan
Aug 30, 2015 10:13 AM
Jandreu
Aug 29, 2015 07:31 PM
dpappyp
Aug 27, 2015 06:31 AM
