98 xk8 shock assessment
Old Mar 7, 2023 | 06:41 PM
trags's Avatar
Default 98 xk8 shock assessment
Hi, can anyone assist with a standardized parts list for changing front / rear shocks...ie: ( Bilsteinn B4 shocks bushings, mounts etc ) like how many & which items are needed before doing the job....also any links to recommendations of parts shops....thanks
Old Mar 8, 2023 | 01:11 AM
Pistnbroke's Avatar
Welcome but fill in your details as at present we dont know what country/state/city you are in to recommend a supplier.
Old Mar 8, 2023 | 02:45 AM
trags's Avatar
Default 98 xk8 shock suppliers
Hi, thanks for responding...I'm in Hawaii, so we have the basic auto parts stores like NAPA, O'Reilly, Checkers etc....as well as ebay & Amazon for parts access....I'm mostly wondering what bushings, mounting plates etc are recommended to have / change along with the Bilstein B4 shocks....looking to do both front & rear...reason being is that there's a significant bottoming out clunk when going over speed bumps, pot holes etc from both front & rear....Mahalo from Hawaii
Old Mar 8, 2023 | 03:08 AM
Pistnbroke's Avatar
First you need to measure from wheel centre to the edge of the fender ..should be 16.5 in . If its down to 14.5 ish then you might need new springs and top mounts . this applies to front and rear . The only way is to have a look at the top mount..front is simpler . Pull the cap off at the centre of the top front shock mount (under the hood) and look in at the condition of the rubber. Take the wheel off and look up with a torch at the top mount ..should be about 5/8 of yellow rubber stuff.
How many miles has it done ?
fill in your details and in your signature put what car it is Coup/conv and year .
have a look at this . And there are others if you scroll down.
Custom Front Shock Mount Bushing Process.... - Jaguar Forums - Jaguar Enthusiasts Forum
Old Mar 8, 2023 | 06:56 PM
trags's Avatar
Default Fender height
I measured the wheel center to fender height & it's 14 1/2" in on all 4 wheels...also front top bushing mount looks worn ....thanks for the links & tips
Old Mar 8, 2023 | 08:48 PM
baxtor's Avatar
Curb height, that is as you would drive it, should be 400mm front and 405mm rear with a 12mm tolerance.
Old Mar 9, 2023 | 08:33 AM
fmertz's Avatar
Clunking noises from the front are typically due to worn/collapsed anti-sway bar bushings. There are cheap Uro replacements available. The bolts to the U clamps are a bit tricky to work out but nothing out of the ordinary. From memory, nothing else needs to come off. Some replace the end links as well but they seem much more durable.
Best of luck, keep us posted.
Layla801
Jan 13, 2023 10:11 AM
66RBS
May 12, 2022 07:26 AM
Salu498
May 30, 2016 03:14 PM
stetson1
Feb 26, 2015 09:09 AM
catob
Aug 31, 2009 09:57 AM
