99 XK8 Center AC vent fin replacement
Old Apr 23, 2013 | 07:16 PM
walstonr's Avatar
Question 99 XK8 Center AC vent fin replacement
I have loose center AC vent fins and have been told that if the vent is removed, the vents can sometimes be put back in place?
Is there any instruction on how to remove the center panel that has the vents installed. And is the above comment about putting the fins back in place true?
Ron
Old Apr 23, 2013 | 08:03 PM
Jag#4's Avatar
Here is a video from our own Reverend Sam. Not sure if you have gauges or nav unit, but it works for either. Once the panel is off, the rest is just taking out the screws that hold the plates on.
Are your vent bars missing? Mine were out of the slots, but I managed to put them back in place from the front without taking off the fascia. Pair of needle nose pliers, tweezers and lots of patience. They are as good as new now.
toronadomike
Jan 22, 2026 10:13 PM
way2far
Aug 31, 2022 09:26 AM
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
