99 XK8 oil pump replacement...
Old May 2, 2014 | 01:29 AM
Bowmanconsult's Avatar
Default 99 XK8 oil pump replacement...
I have heard that there's little to no clearance on the oil pan in order to replace an oil pump.
Certain body braces that need to be taken off?
If anyone can direct me to the proper procedure, that would be greatly appreciated, as I can't find anything here on the forum nor YouTube.
Thanks in advance!
Old May 2, 2014 | 02:48 AM
The JTIS procedure is detailed in the following section:
JTIS - XK8 Oil Pump.pdf
This refers to the following sections:
JTIS - XK8 Camshaft Inner Sprocket.pdf
JTIS - XK8 Primary Timing Chain LH.pdf
I'm sure members who have replaced the oil pump will have some shortcuts.
Old May 2, 2014 | 11:51 AM
Thanks Graham!
Boy...the longer I have this car, the less I seem to know about them.
I assumed the oil pump would be located in the oil sump pan.
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
Jandreu
Jun 30, 2022 03:10 PM
kelliott
May 31, 2022 05:26 PM
giandanielxk8
Sep 6, 2015 07:21 PM
